Stucco Pealing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2009, 08:54 AM   #1
cac
stucco pealing
i had a deck done about 3 years ago. the deck is supported by cinderblock columns covered in stucco. the stucco is bubbling and falling off and i see powdery white that i assume is lime. how do i repair and how should the initial application have been done?
cac is offline   Reply With Quote
Old 01-19-2009, 10:14 AM   #2
Registered User
Termite's Avatar
Sounds to me like their initial scratch coat was poorly done, or there is water infiltrating into that masonry column. Does the column get wet on the top? If so, that would be the problem.
Post some pictures if possible.
Old 01-19-2009, 05:16 PM   #3
cac
the top of the column is filled in. I wonder if they never did the scratch coat.
Old 01-20-2009, 08:07 AM   #4
Rewards Points: 1,232
It is water getting into the columns and exiting through the joints. Even filled solid the columns should be cap flashed.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-20-2009, 08:54 AM   #5
Registered User
Termite's Avatar
Yup. The top of that column should be capped with something that water cannot permeate. Metal flashing would be the best option. If it is simply slugged full of mortar and smoothed off, water will find its way in pretty easily.
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
Stucco leak (long post) Pat B. General DIY Discussions 1 03-24-2006 06:54 PM
