Stucco Pattern Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 02:07 PM   #1
Unhappy
stucco pattern repair
I have a "stucco" Tudor house. The "stucco" is cement board with a stucco pattern manufactured into it. A house painter two years ago "repaired" some water damage by cutting out small parts of the boards and piecing in new sections, and the "repairs" are much worse now than the supposed damage. It appears to be the mixture of stuff he used to cover the horizontal joint between the older piece of cement siding and the new small pieces of cement siding. The stuff is now wet and lifting up just like wet drywall would do. What is the identity of the correct substance that needs to be trowelled onto the horizontal seam between the two pieces of cement fiber siding to make them appear to be seamless? AS you can tell I know little about this but I need to educate myself so I'm not taken by another "professional" contractor. Thanks for any insight.
Fcatron is offline   Reply With Quote
Old 03-17-2011, 09:04 PM   #2
Registered User
Rewards Points: 4,910
Welcome to the forum!
Pictures would be helpful...
Gary
Tags
repair cement "stucco"
STUCCO Question GrandSportC3 Building & Construction 0 12-12-2010 09:06 AM
Help with stucco repair??? MisterPG General DIY Discussions 2 06-15-2010 06:59 PM
How do I repair large sections of stucco? Replacement Building & Construction 1 08-30-2009 01:02 AM
Stucco repair on the wall and waterproofing - some questions ohman Building & Construction 2 07-02-2009 01:58 AM
Chimney Stucco Repair mikeyboy Building & Construction 7 04-11-2009 12:33 PM
