Stucco Over ICF - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2008, 01:30 PM   #1
Stucco over ICF
Hi,
What can you tell me about stucco over ICF construction? I would like to stucco for low maintainance. I know they have tabs on the outside going into the concrete. Is this a good way to go? How thick should the stucco be so that it both adheres well yet doesn't crack or break anywhere.
Would this be better to use Hardie board? Had vinyl in Florida once--it actually warpped from the hot sun (possible bad installation) not going there again.
agrace is offline   Reply With Quote
Old 08-01-2008, 07:09 PM   #2
ICF Construction
Stucco works fine over ICF, your choices are Acrylic (commonly referred to as EIFS) or conventional 3 coat
Acrylic the installer will rough the surface, spread the basecoat, embed the fibremesh smooth and add more basecoat as needed. Once complete and dry he will add the finish coat/texture/color
On 3 part, they will paper the wall, wiremesh it, brown coat, 2nd coat, top coat
3 part seems like more work but is cheaper!! Don't ask me why.
Acrylic is pretty much sealed, waterproof, 3 part can absorb moisture.
Don't forget to PROPERLY caulk the windows/doors/openings/penetrations once completed, of all the issues with stucco this is the #1 cause of failure
Chris
Chris Johnson is offline   Reply With Quote
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Mounting Hose Reel on Stucco Siding xquercus General DIY Discussions 5 07-03-2008 12:00 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
Stucco leak (long post) Pat B. General DIY Discussions 1 03-24-2006 06:54 PM
