Stucco Mortar Mix OK To Drill Tapcon Screws Into? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 07:49 PM   #1
Rewards Points: 1,584
Stucco Mortar Mix OK to drill Tapcon screws into?
I have "pockets" on my exterior concrete block walls that I have previously hollowed out. Those could be voids left my old electrical boxes or drain pipes that I have since relocated...or new voids opened up in order to tie a new fixture into existing vent stacks.
I hired a concrete contractor to repair these walls.
Large voids he filled in with concrete mix, solid fill.
Smaller voids like electrical boxes and such, he stuff newspaper into adjacent hollow blocks to avoid spilling over, then fill with stucco mortar mix. Specifically the "SAKRETE 60 lb. Mortar Mix Type S".
My question is, when I am attaching wood furring strips to the concrete walls, is it OK to drill holes into the patched areas filled with stucco mortar mix and drive Tapcon screws into them? Or should I avoid those patches and only drill where I have original blocks?
miamicuse is offline   Reply With Quote
Old 11-18-2012, 08:10 PM   #2
Rewards Points: 1,220
Yes, as long as the stucco is 1/2-3/4" and there are other screws on the strip, no issues at all.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is online now   Reply With Quote
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
Drywall screws? Fine or coarse, tip for my drill yummy mummy Building & Construction 31 09-27-2007 03:15 PM
These Tapcon Screws Are A Bear Stingray Remodeling 14 04-23-2007 08:40 PM
