Stucco: Is It Better To Use 1 Coat Of Of Finish Coat Throughout Or 3 Coat System? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 08:34 AM   #1
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system?
Hi. I closed up two windows and have plywood, felt/tar paper and wire mesh over the outside. Is it better to use 1 solid coat of of finish coat throughout or the 3 coat system with scratch, base coat and a thinner finish coat? The spacing is about 1-1.25 inches between the existing stucco and the outside of the wire mesh to be stuccoed.
Thanks guys!
psubaron is offline   Reply With Quote
Old 10-05-2011, 10:32 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Three part, there is no single coat system for 1-1/4" stucco.
Well not a single coat of stucco only. There is a system that takes a 1" foam then you stucco over that.
Andy.
AndyGump is offline   Reply With Quote
Old 10-05-2011, 11:06 PM   #3
The mason I talked to said he can do a single layer of finish coat to stucco the windows and complete the job the same day. He said the finish coat material has the water proofing agent in it whereas the scratch and brown coats do not.
What to you think?
Old 10-05-2011, 11:46 PM   #4
AndyGump's Avatar
Rewards Points: 688
He probably knows better than I do.
Andy.
Old 10-05-2011, 11:50 PM   #5
Okay thanks for your input and honesty. The standard is the three coat process so I would normally tell someone asking the same thing.
Old 10-06-2011, 07:48 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
I have my doubts about the water proofing top layer....stucco by nature is not water proof....one of the reasons you have felt on the back side.....and one of the reasons it is not typically used in cold climates that sees a lot of freezing.
The current standard for my area is to no longer stucco all the way down the wall to the ground....you stop at the edge where the sheathing meets the foundation....weepscreen goes on that edge to allow moisture to drain....
I would go 3 layers.....it seems to be the proven process.....
Some 'why', not 'how', questions on stucco usage joeyboy Building & Construction 4 06-25-2007 10:22 AM
Stucco on interior cmu/fireplace andys Building & Construction 1 06-24-2007 03:02 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
Mudding Finish Is Showing on Final Coat Hages Painting 7 03-19-2007 10:09 PM
finish coat over painted walls a_theater_god Remodeling 2 07-30-2006 10:27 PM
