Stucco Around Curved Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 05:45 AM   #1
Stucco around curved window
How do you stucco around curved vinyl clad window. Is there curved lath?
Can metal lath be bent?
Gary Brownlee is offline   Reply With Quote
Old 05-09-2010, 12:15 PM   #2
Rewards Points: 5,336
Metal lath is an open mesh material that will conform to curves.
Ron
Old 05-09-2010, 02:35 PM   #3
There is a metal J mold that goes around every window and door as part of the lath. It provides a surface to screed to. It does not bend for round windows.
Ron
Old 05-09-2010, 04:15 PM   #4
Ron
I've never seen that j mold material on any houses around here. Stucco houses here were mostly built in the early 1900's to the '50s. The stucco would be applied right up to the doors and windows.
If this j mold part of the new stucco applications?
Ron
Tags
curved stucco
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Window replacement / Stucco or Drivit buckwillis Building & Construction 1 01-18-2008 08:49 AM
