Stucco Application - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 06:45 PM   #1
Unhappy
stucco application
I have a 3 ft high concrete block wall that I want to stucco. Earth is on the other side, with plastic sheeting on the wall, but dampness still comes through. Any way to stop the moisture so as to apply the stucco successfully?
carolandfritz is offline   Reply With Quote
Old 03-26-2010, 09:06 PM   #2
Rewards Points: 5,336
The issue you have is that the area behind the wall is incorrect. There should be a stone drainage layer separated by a landscape fabric behind the wall. Do this and the wall will dry out.
Ron
Old 03-27-2010, 06:57 AM   #3
Hi, Ron. Thanx for answering. Unfortunately, the area behind the wall is already filled in, and as it is about 100 feet long, impractical to do as you suggest. I have heard of a product that, when applied to outside surface, stops the moisture by sealing, and allows successful application of stucco. I do not want to do this if it will not work...too much work and expense. Your ideas would be much appreciated! Fritz
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
