Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 08:44 PM   #1
Stucco
Is it good idea to do exterior wall Stucco during this time of the year say 40 to 42 degree.
And the temperature drop to 30 at night. The exterior wall is wood presently cover with shingle. I am planning to remove the shingle up to 3 feet above ground, install wire mach over the existing exterior wood and apply stucco cover. Is there any suggestion if I have to do it what kind of precaution should I taking to protect the wood wall?
bolesrs is offline   Reply With Quote
Old 12-07-2009, 09:13 PM   #2
Registered User
Rewards Points: 5,516
These may help you: http://books.google.com/books?ei=Vu8...G=Search+Books
Be sure to use the proper paper: http://www.fortifiber.com/pdf/fortif...sk_vs_felt.pdf
And plywood, not OSB: http://www.eima.com/pdfs/The%20Perfe...r%20Stucco.pdf
The furnace has a clearance distance printed inside the door.
Be safe, Gary
Chimney Stucco Repair mikeyboy Building & Construction 7 04-11-2009 11:33 AM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 10:04 AM
