Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 04:22 PM   #1
Stucco
Well I decided to renovate the addition to my house which my laundry machines sit in once i started I became aware that the people who built this addition had no idea what square is or how to use a level. I removed the old exterior door which left me with a completely crooked opening to installed a new pre hung exterior door I did manage to pull that together .I then went out side and around the base of the cut the old sheathing which was rotten due to the lack of knowledge when being built. So i took all the correct steps the re due the sheathing. Then all the steps to re apply the stucco for the siding which was a challenge but I did successfully do that. But I have ran into this problem see there is a 2.5 inch gap between the molding on the door frame and the stucco. This gap is to little for me to install the sheathing let alone the paper the wire and the stucco, i was thinking about cutting the stucco off a big enough area around this gap to allow me to add the sheathing and so on to be able to stucco it. Seeing as this gap is only 2.5 inches I was wondering if there is any other ways I could possibly do this so that I end up without that gap and get the weathering protection i need in that area. This has been the most problem sum renovations I have ever ran into and I could use any sorta feed back on this. Anything is better than nothing and it also might save me some work I hope, thanks
B.love is offline   Reply With Quote
Old 10-15-2011, 09:25 AM   #2
Rewards Points: 1,760
Picture would help a bunch.
bob22 is offline   Reply With Quote
Old 10-15-2011, 11:14 AM   #3
Rewards Points: 1,232
You could frame the door with wood trim, or you will have to remove the stucco back far enough to repair it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 06:23 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
