-   -   Structure (http://www.diychatroom.com/f19/structure-158210/)
Travawake 09-27-2012 09:24 PM
Structure
I'm trying to support a 2 story house on one corner by using a 10" I-beam, The beam is about 25' long. Need to know if I put my pier pads about 18' apart can I lift the house approximately 1" to fix the old foundation? The beam will be about 3' from the outside corner on a 45 degree angle catching both rim sills, will it support the weight?
AndyGump 09-27-2012 11:54 PM
Originally Posted by Fairtradeworks (Post 1018941)
The structure is Construct or arrangement of relation between parts of something complicate according to a plans.
Yeah, easy for you to say.
Structure
It will support the weight but the house may collapse around it.
Andy.
GBrackins 09-27-2012 11:59 PM
Travawake,
I do not believe you will find anyone on this forum that will make that determination for you. There are many different types of steel beam and their load bearing capacity is based upon the physical properties of the beam. For example there are 18 different standard 10" W-shape steel beams, and 2 standard types of 10" S-shape steel beams. There is not enough information provided to determine the loads the beam must support.
I know you don't want to hear this, but you should contact a local professional engineer to evaluate your situation and make the determination for the spacing of our pier pads, and whether the beam you have will work. Supporting a building on a steel beam is not your typical DIY project. You need someone knowledgeable and experienced to come to your site and evaluate everything properly. Don't need damage to your home.
If you post on enough sites, or ask long enough eventually you will find someone that will say, "Oh absolutely, that beam is plenty strong enough." This comment is from someone you do not know their level of knowledge or expertise. Realizing this would you take their advise????? If it doesn't work out and you cause damage to the house who would you blame???
Good luck!
mae-ling 09-28-2012 10:41 AM
Yeah - what he said:stupid:
Bondo 09-28-2012 05:40 PM
Ayuh,.... Hard to say,... a 10" I-beam can be a house trailer frame, or have 1/2" web, 'n 3/4" flanges....
The beer can weight 10" I-beam probably would crush, at 2' centers...
A heavy enough beam could carry the Whole length...
tony.g 09-29-2012 01:23 AM
Originally Posted by Thomas152 (Post 1019750)
I identify you don't want to deliberate on this, but you should get in handle with a provincial expert professional to appraise your circumstances and create the determination for the spot of our we blink defends, and whether the glow you have functions. Support a developing on a metal glow is not your typical DIY speculation.
Eh?...
allthumbsdiy 09-29-2012 01:33 AM
Originally Posted by tony.g (Post 1019759)
Eh?...
as DM alluded to in his edit, this is probably another dude (or dudette) paid to troll and spam using free translator.
