Structural Reapirs And Beam Replacment, Nd Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 10:00 AM   #1
Structural reapirs and Beam replacment, nd help
Hi Folks,
I've had a structural engineer provide me with a drawing of structural repairs needed to my 1908 Home. The main beam has to be replaced due to sagging and splitting. (A job i have done successfuly in the past in other homes) I have no fears there.
Second, due to perivous owners removal of structure, cutting joists out, not doubling up Joists and headers at the stairway opening (Which was likely done to make the stair way larger for Modern uses and egress of basement equipment) the floor has sunken badly in the SE corner of the home. I now have to correct the framing, and re level this area. Again not something I haven't done before.
The engineer was clear on all aspects of materials to use, where I have to add a new post etc... But...
My question is this... What repair comes first?
Should i make all the floor framing repairs and sistering of joists first, then start my beam replcement?
My conundrum is that if i replace the beam first, (level the floor and insert my temporary wall) I fear that i will put further stress on the damaged front SE quadrant because when the floor is leveleved at the centre it will put the SE corner area of the floor into a greater sag. but... If i restruture the SE corner floor and stair opening to suit the out of level beam, will i stress the repair points when leveling out the floor at the centre main beam?
I just dont know which area to start first...
The most damage is definately the lack of structure around the SE corner of the house at the stairway opening. It has a sag of +/-2" over 12' in some areas, and requires a new telepost (Where a column was removed)to support a corner.
Any help would be greatly apprciated.
Thank you,
Rob.
thelintonwyrm is offline   Reply With Quote
Old 04-05-2011, 12:30 PM   #2
Rewards Points: 4,442
ask the engineer as he's had actual eyes on the job good luck !
Old 04-05-2011, 12:52 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Very hard to say without at least seeing some good pictures.
Andy.
AndyGump is offline   Reply With Quote
