Structural Question - Modular Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 01:59 PM   #1
Structural question - Modular Home
Hi everyone, I have a question that should be fairly straightforward..
I have a modular home (Cape) which I am finishing the second floor. I would like to cathedral the ceiling in the master bedroom and I currently have 2 things that I am questioning...
1: I have collar ties and rafter ties. Can I remove the rafter ties? I don't think the wall spread would be an issue as the rafters are gusseted with plywood to the floor joists of the second floor.
2: The peak was framed with 2x4's and hinged so it could be built at the factory and erected on site. I will have to sister the 2x4's with 2x8's to match the lower half of the roof. Is there anything else that I am missing? I woulds like to run the new false ceiling to start where the 45 degree supports end.
Thanks for any insight!
drevil is offline   Reply With Quote
Old 02-25-2011, 04:16 PM   #2
Framing Contractor
No one here can possibly answer those questions. You HAVE to talk to the modular company who built it. They are the only ones who can answer for you. You can't assume anything by saying you don't think removing part of the roof is an issue.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-25-2011, 04:25 PM   #3
Rewards Points: 5,336
As Joe said, check with the company who designed the truss structure. They are not ususally meant to be modified. Certainly not without an engineers guidance.
Ron
Knee wall insulation on Modular Home banzaitoyota Building & Construction 6 03-01-2015 12:19 PM
new at home repair HVAC question dixiedarlin Introductions 0 09-19-2010 01:27 AM
First time home buyer with question about results of home inspection. autumnredstorm Off Topic 3 09-18-2010 09:47 AM
Structural integrity question Red Squirrel Building & Construction 8 07-28-2009 10:02 PM
Wiring Ethernet and Speakers in my home question seroth Electrical 10 01-18-2008 03:19 PM
