#1 |
Structural help!
Hello DIY,
New to this forum, first post n all. was wondering if i could get some advice. There is an old chimney running up through the middle of my house that i would like to rip out. But the concrete used for it is holding up half my house. Pictures can be found here! I cut out some of the floor to each side, going to pour some footing for 2 triple stacked 2x6 posts. My real question is do you think that my two posts would hold the weight? |
#2 |
Civil Engineer
Structural help!
This is a pretty serious structural issue, i.e. replacing a concrete support with wooden supports. Taking a poll on an internet chat forum regarding what may be the most important support in your house seems like a bad idea. Really, suppose some says "sure, those posts are good to go." Are you actually going to rely on that type of comment from someone who has never seen your house, does not know what load will be on the posts, and does not know what type of foundation you are going to install for the posts? You need to discuss this with a local professional who can visit your property and offer an informed opinion on the proper support.
| The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post: | itsreallyconc (12-01-2012), mae-ling (12-01-2012) |
#3 |
Structural help!
even a few of us who know what we're doing AND can calculate loads run this by a pe - structural,,, often this type of repair must be permitted & you'll need stamped drawings to pull a permit OR ensure your insurance company'll pay off in the event there's a problem down the road,,, there's much more to it than just holding up the 2nd floor & roof - wind loads, type of current const, & soils also play a part in the right solution
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 | |
Structural help!Quote:
This is definitely beyond the catagory of DYI project. Consult with a local code officer and professional about the renovation before tearing down your house. Secondly, a friend of mine actually was in the same situation, and she built a nice wall storage space on 4 sides of the chimney. Her house was built in the 50's ... your photos look like what hers looked. Good Luck! |
#5 | |
Framing Contractor
So, with that said do you really think that its smart asking advice about a structural issue like this on the internet makes sense without someone looking ar your house? Don't come back saying this is the reason why you're here asking for advice because this isn't a place for it . Who told you to put triple 2x6's there?
Joe Carola |
#6 |
Structural help!
Being serious here. Building permit posted on my most visible window = $50, inspections passed = a beer and a conversation with the only guy in my towns engineering department. While he may be a friend of mine, hes as crooked as they come. Politics aside.....
I appreciate the feedback, the only answer i got is the one that i had expected. I already called a real engineer, just can't be here for a week and a half. Ive got other things i can do, just getting impatient for this particular one. That being said, going to wait for the engineer. Thanks for the input, it is appreciated! |
#7 | |
| Display Modes | |
| Brick veneer or Structural Brick? | nimblemotors | Building & Construction | 19 | 02-22-2013 09:11 PM |
| non-combustible structural framing | hellonoko | Building & Construction | 6 | 05-03-2012 06:31 PM |
| Best way to repair rotted structural wood member? | miamicuse | Carpentry | 20 | 11-19-2011 05:30 PM |
| Opening up a load-bearing wall. Do I need a structural engineer? | Ironlight | Building & Construction | 3 | 04-18-2011 12:03 PM |
| Concrete steps and stucco cracked-Is this structural problem? | yummy mummy | Building & Construction | 17 | 04-14-2008 10:24 AM |
