Structural? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 05:53 PM   #1
Structural?
Hi there
I'm attempting to open up the space under my basement stairs and I noticed this header 2x4 is right under the joist. Would it be safe to take one of these vertical 2x4's out to make a larger opening for storage? Any help would be appreciated...Thanks!
Tibz35 is offline   Reply With Quote
Old 11-09-2012, 05:59 PM   #2
DIY staff
Rewards Points: 7,174
Not structural--a partition---
gregzoll (11-09-2012)
Old 11-09-2012, 06:10 PM   #3
I was thinking of doubling up on the 2x4's - two on the end, take one out, and then double it up again...Just so I have a 30-32" opening...
Old 11-09-2012, 06:48 PM   #4
Rewards Points: 6,652
If you are putting in a door to close off the space, yes moving one stud over, and adding another would allow you to keep that entry from flexing, when you open and close the door.
Old 11-09-2012, 08:07 PM   #5
DIY staff
That partition was added after the reaming of the floor--after the basement floor was added---it is not holding any thing up---
If the partition is to be finished with drywall---double the end 2x4s to keep the wall ends straight---
If you add a doorway--those studs need to be doubled for enough strength to hols a door and nail in trim.
Old 11-09-2012, 08:38 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the others are right.. its just a partition wall.. only reason i can figure using the double 2x4 header isnt for keeping things straight but to provide more meat to nail header trim to
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
gregzoll (11-10-2012), oh'mike (11-09-2012)
Old 11-09-2012, 09:12 PM   #7
Perfect Thanks!
Old 11-10-2012, 05:36 PM   #8
Registered User
Rewards Points: 5,212
Keep safety in mind: "R302.7 Under-stair protection. Enclosed accessible space under stairs shall have walls, under-stair surface and any soffits protected on the enclosed side with 1⁄2-inch (12.7 mm) gypsum board" From: http://publicecodes.cyberregs.com/ic...9_3_par059.htm
Gary
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
Opening up a load-bearing wall. Do I need a structural engineer? Ironlight Building & Construction 3 04-18-2011 12:03 PM
Newbie with structural problem lily1 Building & Construction 7 05-16-2008 06:44 AM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
