Structural - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 02:51 PM   #1
Structural
How much weight will three 2X10's thru bolted together hold on a span of 16 feet
DanRSmith is offline   Reply With Quote
Old 08-15-2011, 02:58 PM   #2
Framing Contractor
Rewards Points: 98
That will probably only hold itself
sixeightten is online now   Reply With Quote
Old 08-15-2011, 03:04 PM   #3
Experienced
Jackofall1's Avatar
Welcome Dan, to the best darn DIY'r site on the web.
You might want to clarify the question slightly, at least in order to get a better answer.
Structural questions or should I say answers always weigh heavy and there is a concern for liability and responsibility that responders need to consider.
Mark
Old 08-15-2011, 03:15 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 840
The real question is how much weight and where your wanting to put on it.
Any time your thinking of bolting sawn lumber together to increase strenght, then you need to start thinking PSL or other options.
Something to consider....you can get more strenght by ripping lengths of 1/2 Struct 1 plywood and nailing/gluing them on both sides of the 2x10. It will add considerable stiffness without that much additional weight.
Once again, the real key is what you want to do with it.
For the record....per typical building codes, the allowable span for 2x10's is 16' using 16" OC. That is for a typical 40 psf load.
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
Opening up a load-bearing wall. Do I need a structural engineer? Ironlight Building & Construction 3 04-18-2011 12:03 PM
Unstable Structural Wall joe_cole5000 Building & Construction 8 02-01-2010 09:33 AM
Structural integrity question Red Squirrel Building & Construction 8 07-28-2009 11:02 PM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
