Old 06-29-2012, 09:42 PM   #1
Question
STRONG Anchor to metal studs
Hey guys,
I have what probably is a unique situation. I own a personal training studio and run quite a few group personal training sessions. In these sessions I have some of my participants use something called "battle ropes" which I thread through a special anchor I had made for them.
This anchor is basically a flat piece of steel with a loop sticking out of it. It has one hole above loop and one below for anchoring purposes. My question is, what is the most secure way to anchor these to metal studs through sheet rock? My participants will be slamming the ropes down forcefully which does create a great deal of sheer and force coming out from the wall.
The previous anchor I tried was I attached a 2x6 cut 6' tall to the wall vertically centered down a stud and attached it with 3" metal stud screws (have a drill tip). Probably about 10 attachment points vertically down the 2x6. I then attached a 2" piece of metal pipe with floor flanges to the board for my anchor. This lasted about a two weeks before the wood was pulled from the wall.
Thanks guys for any help!!
smouton1 is offline   Reply With Quote
Old 06-29-2012, 10:15 PM   #2
Persona Non Grata
VIPlumber's Avatar
So you had a 2x6 piece of wood anchored to a metal stud? What gauge is the metal? The metal studs I'm familiar with are far to flimsy to be able to withstand the kind of lateral force you're talking about. When the last attempt failed did it also damage the sheet rock behind the anchor?
VIPlumber is offline   Reply With Quote
Old 06-29-2012, 10:33 PM   #3
With the kind of force your talking about the screws just stripped through a light gauge metal stud. Without cutting some drywall to add some better attachments... hmmm.. Do you have access to the other side of the wall? Do you know if it is a 4 1/2'' wall or a 6 1/2'' wall?
CopperClad is offline   Reply With Quote
Old 06-29-2012, 11:54 PM   #4
The studs are at least 18 gauge. No, when the anchors were pulled out, they literally came straight out and only left the hole where the screw was. This is an exterior wall but it is a metal building so their will be some space here. Not sure, but if I had to guess it would be 4 1/2
Old 06-30-2012, 07:50 PM   #5
If you want to be sure, one way would be to cut out the drywall, install solid wood blocking between the studs, screwed in from the sides. Put drywall back on, finish, and put in your hardware directly onto the wood. use 2x12 or something similar.
chrisBC is offline   Reply With Quote
Old 06-30-2012, 07:59 PM   #6
Weld the brackets to the metal building.
epson is offline   Reply With Quote
Old 06-30-2012, 08:42 PM   #7
Could you run a steel post floor to ceiling and mount to this?
Attached to floor and then to rafters in ceiling
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
hand drive (07-01-2012)
Old 07-01-2012, 10:25 AM   #8
AHH, SPANS!!!
floor to ceiling sounds best for sure. probably have to get up into the open above ceiling height to find solid to mount to.
hand drive is offline   Reply With Quote
Tags
anchor, metal, studs
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
Can I frame with wood on a building instead of metal studs EHouse Kitchen & Bath Remodeling 4 01-12-2011 11:19 PM
metal studs, best screws to use for attaching cabinets? cbushrun Building & Construction 6 03-29-2010 07:10 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
