Stripping Over CMU For Vinyl - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 09:37 AM   #1
Stripping over CMU for Vinyl
I am planning to strip out the block on our walkout basement to cover it with vinyl. I was planning to use 1x2 treated strips, liquid nailed and T nailed and then use a double dipped roofing nail. The problem is, I can't find a 3/4" roofing nail that isn't electroplated. I don't like the idea of using non PT lumber but I'm not sure what my other options are.
behrend is offline   Reply With Quote
Old 07-14-2010, 09:54 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
id use them or you could go to a stainless or copper roofing nail,the newer pressure treated wood is less corrosive than earlier versions
Tom Struble is offline   Reply With Quote
Old 07-14-2010, 10:03 AM   #3
Tom - When you say you would use 'them', which them are you referring to? I called all around yesterday and in NW Pennsylvania, I couldn't even find stainless nails. I hit HD and Lowes and no luck there either.
Old 07-14-2010, 10:15 AM   #4
i would use the electro plated roofing nail,but thinking about it more,depending on how thick the lock and nailing flange your siding has 3/4'' are probably not long enough,you may need 1 or 11/4'' nails
replacing weather stripping on front door cao911 Remodeling 5 09-07-2012 04:29 PM
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 10:58 PM
Stripping paint from exterior brick Chris squared Painting 2 06-30-2009 06:12 PM
Stripping paper messing up woodwork saggdevil Painting 2 06-08-2009 06:05 PM
weather stripping sticking to my new door? joeyboy General DIY Discussions 1 12-02-2007 01:43 PM
