Old 02-28-2009, 06:40 PM   #1
I have gas!
Clutchcargo's Avatar
Stringer Hanger Board on 2x8 Joists???
Typically you would use a plywood hanger board to attach the stringers to the joists as depicted below. The problem is, my joists are only 2x8s. Can you still use this hanger board method?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-28-2009, 09:05 PM   #2
Old School
Willie T's Avatar
I'd like you to imagine yourself jumping up and down, heavily, on that top step. Do you see how that plywood might tend to fold back under at the lower portion? And at the same time, begin to pull apart up by the floor level?
I think you could curtail this action by screwing and gluing in some 45° (or actually the angle of the stairs, not really 45) blocks of 2 x material right where the stringers are.
Wouldn't hurt to square off the upper back corners of those 45's and install a 2 x 4 ledger across the stair opening, snug up against those angle blocks so they can't shift rearward. Kind of like the 2 x that is affixed to the floor to keep the bottom of the stairs from sliding forward, the thrust plate. (Left drawing)
Of course, if you are able to actually extend the rear portions of those blocks up into the joist cavity, you could nail them to the sides of the joists..... but they would have be solid enough to brace the top ends of the stringers solidly from behind the plywood... and your joist layout may not be suitable for that. (Right drawing)
The whole idea of what I'm suggesting is to keep that plywood straight, flat and solid.
Willie T
Old 02-28-2009, 09:11 PM   #3
Xtreme DIY'r
I guess no chance of installing a 2x support under the top end of the stair riser? I'd never use OSB, maybe 3/4" plywood
Then use some metal hangers - securely nailed into the joist
Old 02-28-2009, 09:33 PM   #4
Old School
Willie T's Avatar
I durn sure agree with using good ¾" plywood, or better yet a 2 x 10 or 2 x 12, but not OSB.
Willie T
Old 02-28-2009, 09:51 PM   #5
Xtreme DIY'r
Another thought is to add another 2x6 directly under the existing 2x8 floor joist. Attach it to the 2x8 floor joist with metal plates. Then go over both joists with the 1/2" or 3/4" plywood
Old 02-28-2009, 10:08 PM   #6
I have gas!
Yes... no OSB, I just used that pic to help me illustrate my problem.
I had a feeling that it would not be the best way to assemble. After some more research, I found that I can move the joist back a few inches and incorporate a few inches of the top landing into the stringer. The stringers would attach like the pic below.
Old 02-28-2009, 10:21 PM   #7
Xtreme DIY'r
The top step of my stringers is even with the 3/4" sub floor
So my stringer lands fully on the joist
I left enough 3/4 sub floor so that will cover the string & all be one piece
So very much like the pic
Top joist that it hangs off of should be doubled
Old 02-28-2009, 10:37 PM   #8
Old School
Willie T's Avatar
Sometimes the architect insists on a flush landing, but I also prefer to build stairs the way his last photo shows. I think it even looks better, and no doubt I feel better about all that stringer end resting way up there on the joist beam.
Willie T
Old 03-01-2009, 12:21 AM   #9
I have gas!
Thanks, this way makes me feel better about the structure. I like to build things that stand on its own even without fasteners.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
