Strengthening A Bouncy Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-02-2008, 04:06 PM   #1
Strengthening a bouncy floor
I have a bouncy floor (too much deflection), and want to strengthen it prior to installing hardwood and tile.
The joists/beams are accessible, and are 16" OC, 15 foot span from beam to beam.
I believe my options are:
1 - add another beam towards the center of the existing joists
2 - add solid blocking or cross bracing between joists
3 - sister the joists
Option 1 seems to be the easiest, since I wouldn't have to modify any electrical or plumbing to do it.
Anyone have any suggestions/experience with a situation like this? I'm fine doing the work, and want to do it once and do it right.
jdelisle is offline   Reply With Quote
Old 01-02-2008, 04:20 PM   #2
Oldguy
Rehabber's Avatar
What size are the existing joists?
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-02-2008, 04:49 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,........ #1 sounds like the Right Plan,........
#2 would require a Ton of blocking,+ I Doubt #3 would do much Good at All.......
Old 01-02-2008, 04:53 PM   #4
Mod / ArchiBuilder
Cole's Avatar
I agree, we need more information!
Cole is offline   Reply With Quote
Old 01-02-2008, 05:02 PM   #5
Sorry forgot to mention - the existing joists are 2x8 spruce, 15 foot span, 16" OC.
I realize the existing joists may not meet typical building code, and plan to talk to the builder about it.. unfortunately the home is 20+ yrs old.
I believe I may be wrong re the additional beam being easiest - it seems teleposts require a minimum of a 30"x30"x30" pad, which mean digging up the basement.. uggh.
So, lets forget option 1.
Old 01-02-2008, 05:20 PM   #6
I wouldn't give up on option 1 yet. Are you sure your area needs a footer requireing nearly a yard of concrete? I poured reinforced footers for lolly posts in my basement and they only needed to be 2' X 2' X 12".
Sistering the joists will probably work but that's not always as easy as it seems. Electrical is usually easy enough to move but plumbing can be a problem.
Bondo - I'm curious why you think sistering the joists wouldn't work. I'm not a builder, but I've done this a couple of times to stiffen a floor so that it would carry stone tiles.
WMitch6 is offline   Reply With Quote
Old 01-02-2008, 05:36 PM   #7
Oldguy
Rehabber's Avatar
Sistering the joists will make your floor feel pretty solid, but not stiff enough for ceramic tile. Adding a cross beam with a support will get you a floor stiff enough for tile or stone
Old 01-02-2008, 05:37 PM   #8
Bondo's Avatar
Rewards Points: 338
Ayuh,.......
The Quickest,+ Usually the Easiest way to tighten or straighten a span in my mind,.......
Is to Shorten it.......
How many 16', 2X8s is it going to take to Sister the existing joists,..??...
Turn'em the Other way,+ you need 3 or 4.........
Just What is this Basement Space we've got to work with,..??...
You're trying to Tighten a Floor,....... Not Jack the Whole House........
No Way you need a couple Yards of Concrete........
Old 01-02-2008, 06:40 PM   #9
I talked to a guy from the city home inspection office, he suggested the 30x30x30 footings. Seemed awful large to me too, but he says because it's a split-level (two story) home and the basement pad isn't load-bearing thickness, it would need that footing under the teleposts.
I do plan porcelain tile above this in one room, by the way. The rest will be hardwood.
Thanks for all the advice so far.
Old 01-02-2008, 06:57 PM   #10
Oldguy
Rehabber's Avatar
Your current deflection calculates at L166. If you sister the joists it will bring you to L332, still not enough for ceramic tile which requires a minimum of L360. If you can add a cross beam in the middle (with supports) you can get this all the way up to L946. Or maybe sister with 2x10s?, which would get you above L360
Old 01-02-2008, 07:23 PM   #11
If I sister with 2x10's, I'll need to notch the ends a little so they'd fit on the current beams beside the existing 2x8's. Think that would be OK?
Old 01-02-2008, 08:21 PM   #12
Oldguy
Rehabber's Avatar
Yes, that will work
Old 10-30-2012, 06:42 PM   #13
Give me a call. I am sure I can help. WWW.LUXORCORP.COM
gallen12 is offline   Reply With Quote
Old 10-30-2012, 06:47 PM   #14
GBrackins's Avatar
Rewards Points: 2,108
gallen,
sure they got it worked out by now, that was almost 5 years ago
I missed the dates sometimes myself
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 10:53 AM
rubber/vinyl 'bouncy' floor - where? nat22 Flooring 2 09-23-2007 06:02 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
