Strapping In Prep For Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 10:43 AM   #1
strapping in prep for vinyl siding
Hello,
I have read that a lot of water gets behind vinyl siding. I am in the process of strapping over exterior insulation. I am wondering if I should be applying something to the strapping in order to protect the wood from the water.
If so what would be my best option...primer, paint (both), stain, or some other product?
Thanks,
Mike
Mike L is offline   Reply With Quote
Old 09-13-2010, 09:16 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
vinyl siding should not be installed over open strapping,it needs a continuous flat surface beneath it,which can be wood sheathing or foam
Tom Struble is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Questions about paint prep for exterior cedar siding. 240sx4u Painting 4 09-22-2008 10:46 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
