Strapping A Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2008, 05:24 PM   #1
Strapping a ceiling
Can anyone explain this method for me:
"On pitched ceilings, it may help to use a chalk line and level to ensure straight lines. Also, the use of a Nail Gun is very helpful in this task, as nailing over one's head can quickly become tiring. Not to mention, the job goes much faster."
I just strapped and sheet rocked a ceiling but on part of the strapping hangs about a half in two low. How do you guys level your strapping? I could see using shims and a level and working down one piece at a time but how does the string work ?
duburban is offline   Reply With Quote
Old 04-12-2008, 07:50 PM   #2
remodeling pro
Once you establish both ends of the strapping to be straight and/or level around the perimeter of the ceiling, you pull the string line down the length of each strap as a straight reference. Clamp the string on both ends with a 3/4" spacer under it, so that it will not be bent any low spots in the strap, then use another piece of the 3/4 as a "go/no go" gauge at each joist location. Then tap down and shim as required. This assumes that you have set up the perimeter with the known lowest point as a benchmark, so you will not need to raise the straps, only lower them.
troubleseeker is offline   Reply With Quote
Old 04-13-2008, 01:34 AM   #3
Thanks, makes perfect sense! Wish i had done that 2 days ago.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 10:55 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Ok to run wiring between strapping in the ceiling? peeks Electrical 5 08-29-2005 12:12 AM
