Strange Brown Spot On Window Sill - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2008, 09:43 PM   #1
Rewards Points: 274
strange brown spot on window sill
Hi all, don't know if anyone can help but wife is worried about a leak and wanted me to ask.....:
New construction, we have a brownish slightly raised spot about 3" by 1" on one of our bottom window sills where the sill meets the window. the sill is made of 1" MDF and has a couple of coats of semi-gloss paint on it (I installed and painted). The window gets alot of afternoon sun, could that warp/stain MDF? Any opinions..... thanks.
ugabulldog is offline   Reply With Quote
Old 05-18-2008, 08:16 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is taking a picture and posting it possible?
- Build Well -
Old 05-18-2008, 09:40 AM   #3
is the brown spot where your cat sits ?
nacko is offline   Reply With Quote
Old 05-18-2008, 10:34 AM   #4
Rewards Points: 274
up close picture....
Old 05-18-2008, 12:07 PM   #5
Looks like a water stain to me. We usually see these in such a location, because the window is leaking from above that area, and it is dripping directly onto that point. The water then causes the MDF to swell up.
- Build Well -
Old 05-18-2008, 01:15 PM   #6
Custom Cabinet Maker
Water stain to me also
skymaster is offline   Reply With Quote
Old 05-18-2008, 02:39 PM   #7
yea, its a water stain.
badnews582008 is offline   Reply With Quote
Old 05-18-2008, 08:34 PM   #8
Rewards Points: 274
any ideas on how to go about diagnosing problem area or how to fix??? it doesn't appear to be dripping from top of window as no brown spots on top (will double check next time it rains)... It is showing up on two windows (both on gable ends of house with roof overhang farther up than other windows. Windows are vinyl low e, vinyl siding exterior. I personally saw weatherproofing tape covering all 4 sides of windows before siding was installed (it is code here I think) House is less than 1 year old.
Old 05-18-2008, 08:42 PM   #9
Next rain storms, check those windows. The first course of action is to fix any leaks. Water could also be coming in from above the windows and leaking down "through" them...
Second: Remove those pathetic MDF sills (stools) and replace with real wood.
My 2 cents....
- Build Well -
Old 05-18-2008, 09:38 PM   #10
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Could it be from condensation on the windows runing on to it?
Sir MixAlot is offline   Reply With Quote
Leaky window (sill) sable General DIY Discussions 5 10-08-2007 11:50 AM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 10:24 PM
Replacing the Sill on a Double hung Window Marshall Building & Construction 2 03-30-2007 12:18 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
brown spot in lawn. stevez Landscaping & Lawn Care 5 06-18-2006 02:16 PM
