Stove Heater Pipes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 09:08 AM   #1
Question
stove heater pipes
I have pulled a cast iron stove insert out of a stone woodburning fireplace. now there is a remaining heat delivery system that has three 4" pipes running directly across the flue, and I think is inhibiting the flow of smoke up the chimney. This is causing smoke to backup into my home. I have cleaned the chimney and can see that there is no major obstruction blocking the flow except the pipes for the heater. I am going to cut two of the three pipes out of the flue area and don't know the best way to
1. Cut through the cast iron pipes(angle grinder, sawzawl?)
2.How to seal the open end of the pipe after it is cut, it will be exposed to some heat and I am not a welder.
Any advice would be greatly appreciated.
Bigdogg77
BigDogg77 is offline   Reply With Quote
Old 12-08-2008, 09:40 AM   #2
Whatamess
Post some pictures if you can
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Turn Off Pilot Lighs: Heater & Stove (Flea Fogger) DanaWashburn HVAC 3 10-21-2008 08:16 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
Water Heater Leaking at top pipes Cheezhead Plumbing 1 11-20-2007 09:03 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
