Storm Door. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 08:35 PM   #1
Storm Door.
I have installed a New 36" service door, and now Iam in the process of adding a Larson Storm Door. I did away with the Brick molding and did a Custom trim job, My qustion is I dont need the Brick molding? To install this storm, I had planned to just attach it to the Trim, which is 2x6, Just as long as my rough opening is still within its range? I know this may sound confussing, I sure hope u understand what iam trying to say.
Splinter2
splinter2 is offline   Reply With Quote
Old 06-09-2012, 09:16 AM   #2
kwikfishron's Avatar
Rewards Points: 376
As long as the inside edge of the new trim is in the same place as where the brick mould was you'll be fine.
kwikfishron is offline   Reply With Quote
Old 06-09-2012, 09:23 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
that should work just fine. the profile of brick mold is about 1" thick where it meets/nails to the door jamb and where the storm door rail mounts to the brick mold. your 2x6 would be 1 1/2" thick. as long as you followed the mounting profile of the brickmold as it mounted to the door frame and have about 35 1/2" to 35 3/4" between your 2x6 a 36" storm should work fine. it will stick out 1/2" more than it would with brick mold but no biggie there.
hand drive is offline   Reply With Quote
Storm Door Not Hanging Straight Jay 78 Windows and Doors 14 03-08-2011 03:36 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
