Storing Vinyl Siding In Attic? Deform? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 09:28 AM   #1
Mike K
Rewards Points: 83
Storing Vinyl siding in attic? Deform?
Quick question..
I bought more vinyl siding (Royal woodland 25) than I needed as not to run out of the color.
As luck would have it the supply company who sold me my vinyl siding changed hands (new owner) and will not take any returns. So now Im stuck with 25' length siding Im constantly tripping over in my garage.
Can I store this vinyl siding on a cat walk in my attic in Iowa without it deforming?
rebar is offline   Reply With Quote
Old 08-18-2010, 10:50 AM   #2
fabrk8r
fabrk8r's Avatar
How much do you have? Can you take one piece, or a small piece, and get it to a temperature comparable to your attic on the hottest day to see if it deforms?
Some brands of vinyl siding are prone to deformation just from the heat of the sun.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-18-2010, 11:15 AM   #3
Mike K
Rewards Points: 83
Yea I could try that with a scrap. I will try to contact Royal and get some tech info.
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
