Storage Under Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 08:02 PM   #1
Storage under stairs
I'm trying to figure out a storage system for under a stairway. The only access is from directly behind it , through a door. 24" wide .so its sort of like reaching into the corner of a triangle. This is a hard one
ALFRANKEN is offline   Reply With Quote
Old 01-26-2010, 10:15 PM   #2
Rewards Points: 5,336
A series of roll out bins, reducing in size as you go in. They shouldn't be any deeper then the space you have outside the closet.
Ron
Old 01-26-2010, 11:14 PM   #3
Registered User
Termite's Avatar
Also remember that accessible spaces under stairs in areas that are finished must be sheetrocked. The IRC code requires that for fire protection. If the space is not accessable for storage then no rock is required.
Old 01-26-2010, 11:17 PM   #4
jlhaslip's Avatar
Rewards Points: 390
5/8 fireguard required.
And taped.
jlhaslip is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
