Old 11-02-2009, 12:47 PM   #1
Default Storage in trusses above garage
I have a 24' by 24' garage that was recently built and I'd like to be able to store some items in the truss space above it. It is constructed with 2x4 W trusses and spans the entire 24' length. Would it be safe to put in an access ladder, lay some 1/2" plywood down and store items like Xmas lights and stuff up there? Also I plan to store the stuff toward the outside edges and not in the center of the span.
steve37887 is offline   Reply With Quote
Old 11-02-2009, 01:07 PM   #2
It depends on who you ask. When trusses are built, the buyer designates whether or not to add stiffness to the bottom chord. When they are designed as such, you normally see a 2x6 bottom chord. If they aren't designed for attic storage, then the sheet set that comes with them includes a placard for the builder to nail to every other truss stating that they aren't designed for storage. If those placards are installed, liability is no longer on the manufacturer or the builder. That being said, as the trusses are installed, I have come across situations where three carpenters are standing on the same bottom chord, jumping up and down, to get it to go into place. You also see people storing things in garage rafters all the time, without a problem. My intuition is that christmas lights and the like would be no problem. Any more than that, I would ask the manufacturer for reccomendations for strengtening them. They will probably tell you to sister each bottom chord, and add plywood gussets to each gusseted intersection. Sometimes they even want you to carriage bolt everything in addition to nails. Hope this helps.
CustomBuild is offline   Reply With Quote
Old 11-02-2009, 01:39 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Christmas lights can actually be quite heavy
Depending upon how many & what they are stored in
So just be careful not to put too many in one tote or box
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-02-2009, 01:49 PM   #4
As Custom Build said, look on your truss spec's. Truss manufacturers are building their products stronger now, because of the code, for just that application. http://www.tricountytruss.com/CodeChanges.aspx
It may not have filtered down to your locale yet......
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
More On This Topic
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
The garage is one of the largest spaces in the home and it is usually the most congested and cluttered. A simple solution for garage clutter is to use well designed storage systems. Here is how to design a garage for maximum usability and storage. Read More »
A patio storage space can come in handy for storing plant food, watering supplies, cooking materials, bug spray, barbecue equipment or even a handy deck of cards. Here's how to make one. Read More »
The next tool that we'll need in order to do a setup, is the correct Allen wrench for the truss rod in your acoustic guitar. If you've got an acoustic guitar, a modern acoustic guitar, they almost all will have a truss rod inside of them that is... Read More »
This is Ron with Expert Village and I'm talking about organizing a garage sale. Now, on the actual organization you want to be able to go through and to really look through your boxes. Go through your closets and be realistic. A lot of people when they... Read More »
Wood Trusses for storage space? PaulBob Building & Construction 1 10-12-2009 08:00 AM
Building Garage overhead Storage swenard Building & Construction 11 09-19-2009 02:29 PM
Garage storage, attaching to engineered beams jdcook72 General Discussion 6 06-17-2009 01:01 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 06:57 PM
Building Garage with Engineered Trusses twiles Carpentry 3 07-04-2008 12:30 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
