Storage In Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 08:56 PM   #1
Rewards Points: 154
Storage in attic
Hi All,
I'm thinking of moving my attic hatch for the lower attic space of my side-split to over top of a short staircase. It's currently in an area that I wish to better utilize as storage space.
I'm hoping to find some sort of hatch that can be installed vertically and open as a set of stairs to a short hatch (say 4 feet tall) and then lay some plywood down on top of the trusses (bottom in the middle of the attic under the peak). I'd use this for light storage.
A few questions though...
1) if I sprayfoam under the ply and don't have loose fill above the ply but have it in all other areas other than this 4 foot wide span do you think that would significantly affect the efficiency of the whole attic insulation? I'd use screen to hold the loose fill from getting on the platform.
2) Weight shouldn't be an issue because I'm just looking to store akward things like christmas decorations and the like. Around what wieght should I start to be concerned with? There is a load bearing wall that runs directly to the left this area.
3) This is just in the what if.. phase now, but any other ideas or advice?
Pic of attic:
Thanks!
Pete
pete0403 is offline   Reply With Quote
Old 12-09-2011, 06:19 AM   #2
Nice to see a well insulated attic for a change. I understand that is a lot of unused space, and tempting, to fill it with stuff But that will be hard to properly insulate and use for storage. Foam is good, but since you have trusses(probably 2x4), you would have to build up the bottom leg to allow for lots of foam, under the new floor. And those trusses may not be designed for adding storage space, anyhow.
Old 12-09-2011, 11:08 AM   #3
DIY or die !
Rewards Points: 77
I have an almost identicle situation, and have been wondering the exact same thing. Would you have to build up over the top of the trusses in order to accomodate room for the insulation? How would this be done effectively ?
Very curious to see the outcome of this project. keep us posted !
lewisthepilgrim is offline   Reply With Quote
Old 12-09-2011, 11:15 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Have any of you considered that that space is not intended to support additional weight and will likely cause trusses to separate and ceilings below to crack and sag? just askin'?
The Following User Says Thank You to Bud Cline For This Useful Post:
AndyGump (12-09-2011)
Old 12-09-2011, 05:32 PM   #5
Rewards Points: 154
Yes Bud, I considered that as one of my first concerns. That's my question #2. Would the weight of 3 4x8 sheets of plywood and maybe 200 pounds of stored material spread out over 20 feet be a weight concern?
Looks like I might move the attic hatch but keep it a regular hatch and leave the attic alone. Too bad...I always seem to want more space.
Here's a good article from a guy who tries to persuade people to not do this.
http://jimrooneyonthelevel.com/2006/0729.htm
Attic Storage (What's Legal?) JasonCA General DIY Discussions 15 05-23-2011 05:54 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
attic storage storageseeker Building & Construction 2 01-29-2009 08:02 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Floor an Attic for Storage MrBill_DIY Flooring 5 05-13-2008 06:32 PM
