Old 12-25-2010, 12:43 AM   #1
Stopping Leaks at bottom of wall.
I hope this is the right forum...
I have a sun room that was built onto the house I just bought. It has large windows and astro turf on the floor. It was fine until this last week when we got a monsoon for 7 days. The floor got wet and the bottom of the walls also got wet inside. There is a small concrete raised wall that is about 2 inches that the wall sits on. How do I stop this leak? I have no idea how the walls were built or what they were made of.
Gomezy3k is offline   Reply With Quote
Old 12-25-2010, 06:58 PM   #2
Post some photos on both the interior and the exterior of the wall.
Ron
Old 12-28-2010, 02:05 PM   #3
Ron
I will post photos as soon as I can get my dang camera to work...
Old 12-30-2010, 02:08 PM   #4
OK Got the camera working...
Old 12-30-2010, 02:10 PM   #5
Old 12-30-2010, 02:10 PM   #6
Old 12-30-2010, 02:11 PM   #7
Old 12-30-2010, 02:12 PM   #8
Old 12-30-2010, 02:13 PM   #9
Old 12-30-2010, 02:14 PM   #10
Old 12-30-2010, 04:46 PM   #11
Master General ReEngineer
Bondo's Avatar
Ayuh,... Does the sidewalk pitch Away from the building,..??
Old 12-30-2010, 06:09 PM   #12
Unfortunately it looks fairly flat and no pitch. Whoever put the room addition on did not do a great job....
Old 12-30-2010, 08:02 PM   #13
Bondo's Avatar
It appears the water only has to puddle less than an inch, before it enters under the wall,...
The Only way to Fix it is to pitch the water Away from the wall...
Is the otherside of the sidewalk able to drain,..??
Old 12-31-2010, 12:32 AM   #14
Yes it is part gravel and part grass...
Old 01-01-2011, 07:44 AM   #15
suspect no wtrproofing membrane or flashing inside the wall's surface,,, there are some paintable mtls you can use & thy're on our w/site as links under ' waterproofing ' { no financial interest } otherwise the repair methods going to be extensive & relatively much more expensive,,, NOTHING at ANY apron store will work despite what any clerk sez unless you want to trowel on black asphaltic roofing cement
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
one handle moen bathtub faucett, leaks behind wall desperate Plumbing 2 02-18-2010 10:32 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
Basement leaks in brick wall Nick General Discussion 8 07-18-2006 05:29 PM
