Stone Veneer Weight - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2008, 08:28 AM   #1
Question
Stone Veneer Weight
I am going to install stone veneer on a framed wall. The stone veneer is rather thin, but with thinset and everything, it's going to weigh about 15 lbs / square foot.
The wall is 8' x 8' so the total weight will be 960 lbs! I have been looking for information on how much weight a wall (16" studs) can hold, but have been unable to find any.
Does anyone know if I am exceeding the maximum weight of the framed wall?
kinglerch is offline   Reply With Quote
Old 08-28-2008, 08:57 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I do not know how much load it can take. If you attach plywood to the studs and top/bottom plate it will significantly strengthen the wall. If you do that then no issues for sure with holding up a stone veneer wall.
Brik is offline   Reply With Quote
Old 08-28-2008, 09:39 AM   #3
I was told to put durock or wonderboard on the studs, but I am still wondering if the wall can take almost 1000 pounds of weight.
stone veneer dinodon General DIY Discussions 7 07-01-2008 07:39 PM
stone veneer on fireplace timber Building & Construction 23 12-20-2007 01:37 PM
Stone veneer over foam board. rfjm58 Building & Construction 6 04-10-2007 06:40 AM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
