Old 08-11-2012, 01:30 AM   #1
Stone Veneer Termination at Siding
I'm planning to install drystack stone veneer on the front of my house, the base of two columns, and on the two walls on either side of my garage.
I've found information on flashing between hp siding, and veneer installed below the hp siding. I have not been able to find any information on flashing or terminating the veneer laterally into the hp siding. I'd like to wrap the veneer around the garage corner. Do I just use trim boards (rough sawn cedar is what is on the house now) and caulk between the veneer and trim on one side and hp siding and trim on the other?
This is my first post. Let me know if more info is needed. Thanks in advance, any help is appreciated.
MLiljen is offline   Reply With Quote
Veneer stone over stucco jsumb82 Concrete, Stone & Masonry 2 05-10-2012 07:08 PM
How to buildout veneer stone Itchbo Building & Construction 6 06-11-2011 08:21 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
