Stone Veneer Over Wood Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 10:55 AM   #1
Stone veneer over wood siding
I'd like to install stone veneer on top of wood siding - wainscoting, manufacturer - culturedstone.
The professional installer said he'll do it on top of siding. While the lady at the supply store said it'll be better to remove the siding.
The siding is in fair condition (> 20 years old) except for a couple of strips.
The stone that I'll be installing is country ledgestone - if that matters in installation choices.
Thanks in advance
ukrishnan87 is offline   Reply With Quote
Old 07-27-2011, 02:43 PM   #2
Rewards Points: 5,336
Contacting the manufacturer should get you the approved installation instructions for your application.
They might be on their website.
Ron
B. Franklin 1759
Old 07-31-2011, 07:53 AM   #3
I believe it's better to remove the timber siding. Its 20 yo and you're going to install the stone veneer on it? normally, stone veneer lasts for 25 -50 years easily but what about your old timber siding under. will it last another 5-10-15years? I'm not sure.
CustomMadeStone is offline   Reply With Quote
Old 07-31-2011, 08:51 AM   #4
DIY staff
Rewards Points: 7,174
How could the stone work get properly flashed into the siding if the old siding is left on??
Better make a few more calls----I never heard of that method of installation.
Old 07-31-2011, 10:37 AM   #5
Too Old
Sticking it to the siding is not a proper installation method.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 07-31-2011, 11:30 AM   #6
Concrete & Masonry
Rewards Points: 582
The only kind of siding I could see staying on and working realistically is something like T-111, or of course real brick. As Mike stated, correct flashing will be complicated, if at all possible. Don't fall for the old mis-conception that "Lick & Stick" stone is water-proof
jomama45 is offline   Reply With Quote
Old 07-31-2011, 11:34 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The wood will rot with out the routine availability of circulating air.
End of story.
XXX
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
stone veneer dinodon General DIY Discussions 7 07-01-2008 07:39 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
