Stone Veneer Meets Siding...flashing? - Building & Construction - Page 5 - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 08:59 AM   #61
Tom Struble's Avatar
Rewards Points: 2,002
send a little this way
Tom Struble is offline   Reply With Quote
Old 02-26-2012, 09:04 AM   #62
Originally Posted by loneframer View Post
I'm not as concerned about movement as I am with freeze/thaw. There's also a chance of bulk water being trapped and possible hydraulic pressure, however slight it may be. Damp veneer = algae growth. Keeping it dry on the inside means quicker drying cycle on the outside.
got it,
it's just i thought a grouted angled stone sill applied to a concrete foundation would be able to do this independently of any metal or sealant
but no mason am I
Old 02-26-2012, 12:22 PM   #63
Concrete & Masonry
Rewards Points: 616
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Tom Struble (02-26-2012)
Old 02-26-2012, 05:12 PM   #64
ok ok i'm not a hydraulics expert
Old 02-27-2012, 09:11 PM   #65
Registered User
Rewards Points: 526
Could the OP leave a 1" gap between the stone veneer and the concrete wall?
Wouldn't the concrete wall be (already below grade) waterproofed first?
Wouldn't the flashing metal tuck under the WRB behind the vinyl and (or under the mudsill) extend a little onto the sloped (pitched) stone to run the water from above that point out at the top the stone?
Why need sealant at the top inside of pitched stone if the whole veneer is open air space behind. Solar drive would drain in the air space, and out below.
There wouldn't be any hydraulic pressure if built with an air space and the concrete wall wouldn't get wet to diffuse water inside. You don't want/need a poly vapor barrier below grade. You wouldn't need a WRB behind the stone. You wouldn't get freeze-thaw with an air-space. If in a high moisture area and wanted extra protection, just set the veneer off with a mat; read "Conclusions" pp.9: http://www.buildingscience.com/docum...e_Barriers.pdf
http://www.insulation.net/uploads/pd...20brochure.pdf
A good read for stucco/stone with OSB or plywood: http://www.buildingscience.com/docum...-perfect-storm
Hope this gives you some ideas (food for thought).
Gary
Old 02-27-2012, 10:05 PM   #66
Concrete & Masonry
Rewards Points: 616
Gary,
The 1" airspace is good for a real stone veneer, but the OP is looking to install cultured stone. He could obviously create a rainscreen system behind it, but it would be a ton of work for minimal benefit.
Gary in WA (02-27-2012)
Old 02-27-2012, 10:26 PM   #67
see,turned out to be a fun informative discussion
Old 10-26-2012, 07:55 AM   #68
heinlein0311's Avatar
Rewards Points: 81
It's been a while since I started this project but I finally got it done and used most of ya'll advice. I bought a roll of trim coil, rented a brake and bent some flashing and the installed it under the siding and behind the weather barrier. I than used a water table stone under it with a built in drip edge. The extra cost was about $1000 compared to not having anything to divert the water. Well worth it for peace of mind. Adhering the stone wasn't to bad, time consuming as all get out but well worth what I saved doing it myself and I couldn't be happier with the results. Here's some pics, thanks for all the help
Stone veneer meets siding...flashing?-image-873649180.jpg   Stone veneer meets siding...flashing?-image-140350254.jpg   Stone veneer meets siding...flashing?-image-422569665.jpg   Stone veneer meets siding...flashing?-image-3568927233.jpg   Stone veneer meets siding...flashing?-image-1988021643.jpg
heinlein0311 is offline   Reply With Quote
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 06:39 PM
Flashing to protect wood siding from soil/mulch? lateralus Building & Construction 7 08-24-2011 08:59 PM
Cultured Stone Flashing Details project_guy Building & Construction 4 06-23-2011 12:51 PM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 07:36 AM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 10:50 PM
