Old 02-23-2012, 07:09 PM   #46
Tom Struble's Avatar
Stone veneer meets siding...flashing?
Tom Struble is offline   Reply With Quote
Old 02-23-2012, 07:11 PM   #47
[quote=George*RLCC;861445]Tom this is what i was referring to...
just instead of brick he's going to finish of top of the wall with the siding.[/quote]
No he doesn’t need weeps read above (you're right) but he could a use drip edge.
Veneer its nothing else than a piece of colored concrete he needs a drip edge unless it will suck up all of the water it gets.
George*RLCC is offline   Reply With Quote
Old 02-23-2012, 07:54 PM   #48
heinlein0311's Avatar
What I'm planning on using is a "man made" stone watertable ...I'm running flashing underneath the siding/weather barrier and then having the flashing kick out over top of the water table. You saying I need more than this?
heinlein0311 is offline   Reply With Quote
Old 02-23-2012, 08:54 PM   #49
Concrete & Masonry
You'll be fine, as most cultured sills I've seen already have a drip-edge cast into the bottom of them. Nothing more needed............
jomama45 is offline   Reply With Quote
Old 02-23-2012, 09:03 PM   #50
No you dont need more , thats all in good order ,you just need better.
You need to saw a drip edge on bottom of the whatever is overlapping the stone.
And if i was the one doing this job i would replace thin aluminum coil with 20-22 ga galvanized flashing.
Thin coil wont stay in place right, it needs to be bend so it presses down on the sill-cant do with thin stuff.
Also don’t use silicone caulking use OSI or 9000 solar seal
The Following User Says Thank You to George*RLCC For This Useful Post:
Tom Struble (02-23-2012)
Old 02-23-2012, 09:09 PM   #51
cleated back to the wall will hold it tight,galvi? not sure i would go with any flashing there that could stain
Old 02-23-2012, 09:35 PM   #52
It will stain cedar but not stone-limestone.
Siding guys love that 0.019 coil... Tom ...what kind of coil is that that you can cut it with a box cuter ?
Old 02-23-2012, 09:52 PM   #53
thats the stuff,but if you do it right it's fine
but maybe some of the commercial roofing steel sheet would be a better choice....depends
and there is always stainless
Old 02-23-2012, 09:58 PM   #54
i'm still not buying that masonry can't be installed on to a poured foundation without metal above it,but i like to play
Old 02-25-2012, 09:50 PM   #55
Moderator
kwikfishron's Avatar
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 02-25-2012, 11:26 PM   #56
how ya been Ron?
Old 02-26-2012, 08:21 AM   #57
KemoSabe
loneframer's Avatar
What you need is a sealant applicator to professionally caulk the joint between the foundation and the precast ledge, as well as the joints between the individual pieces. This will be a defense against wind driven rain and negative pressure infiltration. It will also shed away any water that gets on the wrong side of the WRB due to solar drive. Then the flashing can be applied as another line of defense.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 02-26-2012, 09:26 AM   #58
why caulk? seems to me stone veneer cemented to a poured foundation would be monolithic,wheres the movement that would require a flexible sealant?
Old 02-26-2012, 09:31 AM   #59
KemoSabe
loneframer's Avatar
I'm not as concerned about movement as I am with freeze/thaw. There's also a chance of bulk water being trapped and possible hydraulic pressure, however slight it may be. Damp veneer = algae growth. Keeping it dry on the inside means quicker drying cycle on the outside.
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (02-26-2012)
Old 02-26-2012, 09:31 AM   #60
Moderator
how ya been Ron?
Been fine Tom ……buried in work again….finely….can’t keep up.
-NEW MEMBERS-
The Following User Says Thank You to kwikfishron For This Useful Post:
Flashing to protect wood siding from soil/mulch? lateralus Building & Construction 7 08-24-2011 09:59 PM
Cultured Stone Flashing Details project_guy Building & Construction 4 06-23-2011 01:51 PM
Roof to Wall Flashing Installation – Painted Cedar Lap Board Siding Deeppool Roofing 3 12-08-2010 08:36 AM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 1 11-09-2009 05:29 AM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 11:50 PM
