Stone Veneer Meets Siding...flashing? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 11:50 AM   #31
Concrete & Masonry
Rewards Points: 520
Originally Posted by Tom Struble View Post
jo this is why i questioned flashing the sill,couldn't the sill actually be the flashing? wouldn't the stone and poured foundation actually be monolithic so the grout between the stone sill and foundation be adequate?
It depends on where the OP lives somewhat, because the joint between the sill and foundation is certainly susceptable to leakage. If located in a high freeze-thaw region, any excess moisture migration behind the stone is never good. Add in the fact that both types of sill mentioned (by me) so far are extremely absorbent, and draw the moisture from the mortar out quickly during installation, and a hairline cracks are bound to exist in the joint.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Tom Struble (02-18-2012)
Old 02-17-2012, 01:33 PM   #32
heinlein0311's Avatar
Rewards Points: 81
I live in southwest Virginia. We don't get huge freezing spells here but it does freeze once in a while
heinlein0311 is offline   Reply With Quote
Old 02-23-2012, 02:07 PM   #33
Rewards Points: 81
I've been looking around for flashing and was wondering what size you all think. I would like to get some flashing or trim coil in a clay color to match our trim but most if it is 24" wide. I was thinking i needed it 6 or 8" wide. The only thing I can find with that width is aluminum or galvanized steel with a mill finish. Not very attractive if you ask me....I did find some vinyl flashing with the right width and color but Is that a no-no for my type of application? Any feedback would be appreciative
Old 02-23-2012, 03:54 PM   #34
Tom Struble's Avatar
Rewards Points: 2,002
you can use painted aluminum for that,me? i would keep the bend on to the stone no wider than 1 1/2'' hemmed and cleated and up the wall atleast 4''
Tom Struble is offline   Reply With Quote
Old 02-23-2012, 04:06 PM   #35
Rewards Points: 81
That's pretty close to what I was thinking of doing. .....I was just reading on how to use a sheet metal brake.... I've heard the term "painted aluminum" in some research I was doing but haven't seen to much about it. I was looking for flashing or trim coil that matches my trim. Is that the same thing or something different?
Old 02-23-2012, 04:43 PM   #36
wow ...me doing it for 35 years and you just reading about brakes and we come up with the same idea
go where the siding came from and ask for a roll of clay
The Following User Says Thank You to Tom Struble For This Useful Post:
kwikfishron (02-25-2012)
Old 02-23-2012, 05:06 PM   #37
Rewards Points: 81
I found this handy dandy picture, that's where I got my idea
The Following 2 Users Say Thank You to heinlein0311 For This Useful Post:
kwikfishron (02-25-2012), Tom Struble (02-23-2012)
Old 02-23-2012, 06:43 PM   #38
she's a beut
Old 02-23-2012, 06:51 PM   #39
Nice picture but you are better of using limestone instead of brick for the cap.
Limestone cap has a grove on the underside preventing water from running down the wall.
Ask any bricklayer and he will tell you the same thing.
George*RLCC is offline   Reply With Quote
Old 02-23-2012, 06:53 PM   #40
he's using stone
Old 02-23-2012, 06:54 PM   #41
so what...he can still use limestone for the cap ,no ?
Old 02-23-2012, 06:57 PM   #42
i believe he said he was using a stone sill George...ask any bricklayer
Old 02-23-2012, 06:58 PM   #43
Here go i found something similar online....
The Following User Says Thank You to George*RLCC For This Useful Post:
Old 02-23-2012, 07:01 PM   #44
Tom this is what i was referring to...
just instead of brick he's going to finish of top of the wall with the siding.
Old 02-23-2012, 07:03 PM   #45
Concrete & Masonry
Rewards Points: 520
They don't always have a drip-edge sawed into them. As a matter of fact, it's quite rare to see that hear in residential sills. Grindign his own in certainly wouldn't hurt anything though.
he's using stone
I thought so to........
That's a little bit different scenario. That's a base flashing at the brickledge with "Quadra-vents" for the weep holes. He won't really need either in this situation, seeing as it's thin veneer.
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 07:39 PM
Flashing to protect wood siding from soil/mulch? lateralus Building & Construction 7 08-24-2011 09:59 PM
Cultured Stone Flashing Details project_guy Building & Construction 4 06-23-2011 01:51 PM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 08:36 AM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 11:50 PM
