Stone Options For Interior And Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 11:00 AM   #1
Thumbs up
Stone options for interior and exterior wall
I was searching for an easy to install option for stone siding as a feature for the outside of my house. I found a few options (Genstone, Nextstone, and some other terrible ones), and actually bought and started installing some called Nexstone that I saw at a Home Hardware. Then I found one called Quality Stone on the web at www.qualitystoneproducts.com. It actually looks like real stone, and you just have to cut it with a saw and screw it on. I wish someone had told me about this before I wasted money on another product. I ended up doing a bunch on the front of my house, and did a fireplace and feature wall inside.
naddust is offline   Reply With Quote
Old 07-21-2010, 02:14 PM   #2
Rewards Points: 5,336
I thought I read that this product deteriorated when exposed to the elements and in some cases just high humidity caused failure.
Ron
Old 07-21-2010, 03:19 PM   #3
Concrete & Masonry
Rewards Points: 568
That may be somewhat subjective...........
Kind of like saying vinyl siding looks just like cedar siding.........
jomama45 is offline   Reply With Quote
Old 07-21-2010, 03:21 PM   #4
Ray Charles never had an issue.
Ron
Old 07-21-2010, 03:36 PM   #5
Concrete & Masonry
Rewards Points: 568
Ron
I was thinking along the same lines as that...........
Old 07-26-2010, 12:58 PM   #6
Rewards Points: 508
Apparently that NextStone stuff is some sort of polymer or something. It can't be cultured stone, since it weighs only about 1 lb. per square foot. Has anyone ever seen that type of product installed?
How do you feel about cultured stone veneer?
benjamincall is offline   Reply With Quote
Tags
cladding , polyurethane , rock , siding , stone
stone for wood stove hearth pyper Flooring 1 10-24-2011 09:53 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
