Stone Foundation In Barn - Add Lime Or Mortar? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 04:28 AM   #1
Rewards Points: 89
Stone foundation in barn - add lime or mortar?
Hello, I've been reading many threads tonight on this topic. Of course, not every situation is the same.
I have an old barn with a dirt cellar and stone foundation (largish boulders. I'm undertaking some structural repairs myself and am trying to work out the big plan. One of the walls seems to have no mortar for the most part. Two seem to have the remnants of a half-assed patch job ... all crumbling ... looks like "cement" to me. The wall with nothing needs some work, pushing the stones back up under the sill. I then want to bond them in place.
During the massive storms we've had recently in Boston it takes on *a lot* of water (3 feet of standing). The house sump is quite active, as well, or the house would also take on this water. The water table is so high here, I'm skeptical that much can be done to avoid the standing water down there. I mention this so you know what the moisture situation is. Normally, it's dry down there.
If I have to dig externally on the small section that's leaning in, I can do that, but overall, I'm looking to do these repairs from the inside. So ... given the fact that there's water at times, that this is unheated (therefore considered entirely exterior?), that I'm in New England ... what would you do? Lime mix? Mortar? I assume I'd be trying to force this as deeply as I can between the rocks. There are big spaces, plenty where I could fit my fist inside. Actually, even bigger than that. Would it be stupid to think about setting sections of rebar between the rocks "randomly" before packing it all?
Before researching this, I called the local lumber yard and they suggested mixed mortar. Since I don't seem to have existing lime, I suspect this may be an option, but I'm still a bit confused, frankly.
Thank you for any advice!
tbeaulieu is offline   Reply With Quote
Tags
foundation , lime , mortar , stone
Old Stone Foundation Repair Nivk Building & Construction 19 10-26-2014 01:20 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
Insulating a lime mortar stone foundation steveel General DIY Discussions 2 10-01-2010 05:06 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
