Stone Entryway Falling Apart - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 07:23 AM   #1
stone entryway falling apart
Hi, I was replacing my front screen door last night, and mortar along the door frame started falling off.
My 75-year old house is brick, but the front door has rough stone inset around the frame held in place with mortar.
I inspected, and noticed that the mortar/cement from a previous repair was super brittle and literally crumbling at the slightest touch.
The original sanded and tan-colored(lime?) is still in good shape.
I was wondering, after I'm done removing the crumbling mortar, should I apply a cement-type epoxy or hydralic cement?
Thanks!
cmt9000 is offline   Reply With Quote
Old 09-21-2010, 08:20 AM   #2
Rewards Points: 582
The best thing to fill the gap between a timber frame and masonry is burnt sand mastic.
http://masonsmortar.co.uk/site/burnt-sand-mastic.htm
stuart45 is offline   Reply With Quote
Old 09-21-2010, 08:28 AM   #3
Is this something I can get at one of the box stores or do I need to special order? I've never heard of it before. Is there anything else I could use?
Old 09-21-2010, 09:10 AM   #4
Rewards Points: 582
You can make it yourself by heating up sand and adding linseed oil. You can also use a frame sealant, or mix up some lime mortar.
Old 09-21-2010, 09:18 AM   #5
Ok, I just looked at the stone again, and it is actually NOT touching the wooden door frame. There is a 1/2" gap between the wooden door frame and the stone. The stone is mortared to the brick behind it.
So I guess I can just use normal brick epoxy or should I use Hydraulic cement?
Some of the cement will be vertical, so it will need to set fast so it doesn't run out.
Thanks!
Old 09-21-2010, 10:50 AM   #6
Rewards Points: 956
hydraulic is fine. or you can use regular mortar mix. its designed for brick/tuck pointing. just make sure you stuff it in there
federer is offline   Reply With Quote
Old 09-21-2010, 12:18 PM   #7
Rewards Points: 4,656
there should be a sealant 'tween the frame & any masonary work however a mason wouldn't normally even know this as its restoration mason's work, not a reg brickie,,, that's probably why the ' gap ',,, hydraulic cement's absolutely the WRONG mtl,,, properly mixed, regular mortar can be applied vertically & even overhead.
no idea what ' normal brick epoxy ' or ANY brick epoxy is !
Old 09-21-2010, 12:29 PM   #8
sorry, I was just inventing the term 'normal brick epoxy'
So a firm NO on hydraulic cement, and a YES for regular mortar.
Thanks!
Driveway stone falling into ditch over culvert BimmerDOm Landscaping & Lawn Care 7 08-08-2010 08:18 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
