Old 06-03-2007, 02:07 AM   #1
Stone counter fabrication
I've seen a few ways stone counters are fabricated, more specifically how the plywood is backed on it...
1) 2 inch plywood strips around the edge used to screw the counters to the cabinets
2) Fully backed by plywood through out
Obviously option 1 is not as strong, but was wondering how big a difference it makes...
slakker is offline   Reply With Quote
Old 06-03-2007, 01:50 PM   #2
Longtooth's Avatar
If you are ready to spring big $$ for stone countertops, go with solid 5/8" or 3/4" plywood of a good grade for substrait. It will be stronger, gives lateral support to the cabinets, makes appliance and fixture installation easier. Strips would be a cheap out.
Longtooth is offline   Reply With Quote
using faux stone on interior walls...? DIY4EVER Building & Construction 21 12-21-2007 10:43 AM
Pass-thru counter gshock Carpentry 6 07-29-2007 12:44 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
HELP! Question about Eldorado Stone EricW Building & Construction 8 10-24-2006 05:24 PM
