Old 06-09-2008, 10:33 PM   #1
still cant find where water is getting into my basement
found mold on the baseboard in the corner of my basement..i carefully took down the wood paneling, ripped out the sheetrock and insulation and foung some major funky whitish pink mold lookin stuff on one area...lots of grungy look stuff all over the painted cinder block and areas where the paint was peeling off to bare cinder block
i could see a little moisture on the walls in certain spots but not the source..i have a feeling im taking on a job too big for me to handle...its supposed to rain tomrrow night, so im hoping that that will help me find the spots where water is gettin in...
this is most likey being caused by rainwater not draining properly in that corner of the house..the pipe that the downspout connects to has not worked properly in years, according to my parents...
what should i be looking for on the outside of the house? should i start digging outside in the corner also where the faulty drainage pipe is also..
thanks for any suggestions, help
flashme18 is offline   Reply With Quote
Old 06-10-2008, 12:20 AM   #2
It's probably seeping through the cinder block. You'll probably need to rip more off in the corner, then scrape it with a hard brush to clean it. Then apply some kind of water seal paint all over it with a brush. You have to get something like Drylock that can withstand hydrostatic pressure. ALso buy some of that black outdoor piping and divert your downspouts a good ways from your house. I diverted mine about 10 feet through some bushes. That pretty much did the trick. If you do find any visible holes, get some of the Drylock Fastplug sealer. You can mix it in very small batches and shove it into the holes. I usually wear rubber gloves and do it by hand.
jayp is offline   Reply With Quote
Old 06-10-2008, 11:02 AM   #3
You have to fix the outside before you fix the inside.
handy man88 is offline   Reply With Quote
Old 06-10-2008, 04:03 PM   #4
pics would help
ehoez is offline   Reply With Quote
Old 06-10-2008, 06:19 PM   #5
here are some pix...let me know if u need more...im hoping i dont have to open these walls up even more to find the problem.. maybe i can get some free tools out of this job from my parents
still cant find where water is getting into my basement-p6050540.jpg   still cant find where water is getting into my basement-p6090566.jpg   still cant find where water is getting into my basement-p6100570.jpg   still cant find where water is getting into my basement-p6100569.jpg   still cant find where water is getting into my basement-p6090568.jpg
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
hot water heat attic central air...hot basement in summer spttrac214 HVAC 2 02-29-2008 06:24 AM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
