Old 10-14-2012, 06:29 PM   #1
sticky tar paper
what do you call tar paper that you put around the window and it is sticky, comes in rolles
floors N up is offline   Reply With Quote
Old 10-14-2012, 06:35 PM   #2
Super Moderator
sticky tar paper
Window wrap----usually in the roofing/siding section of the home depot----
Old 10-14-2012, 06:37 PM   #3
sticky tar paper
Do you mean flashing??
Canarywood1 is offline   Reply With Quote
Old 10-14-2012, 07:35 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
sticky tar paper
peal and stick flashing membrane, its not tar paper its a rubber based product that acts similar to ice and water shield. only difference is the rubber based stuff doesnt react with the vinyl in most windows causing them to break down
Grace makes Vycor in various widths for just this. same as blueskin. theres also 3m flex flash and resisto flashing membrane
woodworkbykirk is offline   Reply With Quote
Skylight Install: How to Retrofit New Asphalt Paper? amakarevic Roofing 11 06-06-2012 03:01 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing 4 11-24-2010 03:05 PM
Felt Paper and the Sun. Valley problems hartkem Roofing 1 07-22-2009 04:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
