Steps To Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 11:41 AM   #1
jad
steps to patio
Will be building a small deck with a about 3 or 4 steps down to a patio. The patio is made of pavers and my question is this....
Would it be ok to attach (bolt) the bottom 4x4 (railing post) to the step only. Or do I need to dig the post into the ground which would mean removing some pavers?
thanks
jad is offline   Reply With Quote
Old 03-08-2012, 01:19 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You don't have to dig any holes.
install posts inside stringers (through step) for extra sturdiness.
titanoman is offline   Reply With Quote
Old 03-08-2012, 01:41 PM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Unless those posts are also supporting the stairs. Then they need to be on footers below frostline.
12penny is offline   Reply With Quote
Old 03-08-2012, 06:53 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Of course I don't know what your location is as you have not put it in your signature or anywhere else but, assuming your steps are 7 1/2" high the deck then is at about 30" or less.
You may not even be required to have a guard on the deck or the stairs.
Might be a good idea to have them though.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 03-08-2012, 07:31 PM   #5
Disabled wood vet
titanoman's Avatar
California is anything over 11".
Kinda' crazy.
Old 03-08-2012, 07:36 PM   #6
AndyGump's Avatar
Rewards Points: 684
R312.1 Where required. Guards shall be located along open-sided walking surfaces, including stairs, ramps and landings, that are located more than 30 inches (762 mm) measured vertically to the floor or grade below at any point within 36 inches (914 mm) horizontally to the edge of the open side. Insect screening shall not be considered as a guard.
Andy.
Patio Steps DIPPY Building & Construction 1 09-02-2011 07:51 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
Steps to the patio munibroker23 Landscaping & Lawn Care 1 04-05-2010 11:39 AM
steps up from concrete patio annrose Landscaping & Lawn Care 2 09-10-2009 07:07 PM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 07:15 AM
