Steps In Front Of Bathroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 11:22 AM   #1
Steps in front of Bathroom
We recently remodeled the back room in our 1925 bungalow. The room is in an addition that was built in the last 15 years. It used to be a porch that was converted into a den. We converted into a second bathroom and a laundry room. We put down wood laminate flooring. There is a large drop where the back stoop of the house used to be. The bathroom door opening is directly below the step down. The step is about a foot and a half. We would like to ening where the step should be buitl?add another step between the landing and the floor. How should we approach this since we have to deal with an o
Steps in front of Bathroom-image-393715499.jpg   Steps in front of Bathroom-image-2434694166.jpg   Steps in front of Bathroom-image-1606537071.jpg
BenJBailey is offline   Reply With Quote
Old 02-16-2013, 11:23 AM   #2
...opening where the step should be?
Old 02-16-2013, 04:27 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,.... Hang a short door that closes over the step yer gonna build...
Old 02-17-2013, 08:14 AM   #4
Rewards Points: 1,494
The best thing is to split the landing between the bathroom door and the other door to have an intermediate step (check the International Building Code to see if you need two steps).
This will require re-engineering the joists under the landing. It might be possible to cut the joists as thin as 2x6 quality and sister 2x8 or 2x10 sections (depending on horizontal span) to the affected portions. An additional support column will be needed underneath.
If you succeed in doing it this way, install banisters so guests will realize that there are steps.
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
How to build front entryway steps pttcc Building & Construction 2 02-14-2011 03:07 AM
Steps in Complete Bathroom Remodel JayG Kitchen & Bath Remodeling 3 02-01-2010 03:41 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
