Steps For A Deck That Is Low To The Ground - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 07:11 PM   #1
Steps for a deck that is low to the ground
Hi everyone,
I put a deck on the side of my house. I need to put a step or 2 to get on it from my yard. Pre-made stringers come in 3, 4, 5 steps etc. I only need one or 2 and I don't know how to make the stringers from scratch. What would you do? Here is a pic. Thanks.
Smoke is offline   Reply With Quote
Old 04-29-2012, 07:18 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Create a slightly raised, reinforced, textured, concrete landing pad that is the same width or +2" wider than the step down width, the same rise as the the deck joist (approx. 7" +/- riser), and 12" + depth (dependent on where the natural step-down stride puts your footprint).
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
DrHicks (04-30-2012)
Old 04-29-2012, 10:14 PM   #3
Rewards Points: 214
You can make a concrete landing pad as the previous poster stated or an even cheaper solution would be to frame out with landscape posts and then fill with gravel. That looks good with landscaping and decks.
The only issue would be if you expect ladies in high heels. In that case go with something more solid such as concrete or large pavers....
Good luck
Ralph III is offline   Reply With Quote
Old 04-29-2012, 10:16 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
by the height of the drop it looks like you could build a 16" deep by 48" wide landing made out of 2x6 or 2x8 ground contact pressure treated lumber, attach landing to deck and put three deck treads on top. finished.
materials list - 1- 2x6 or 8 x 16' , 1 - 5/4 x 6 x 12' decking plank
also, maybe a random treated 2x4 for attaching landing to deck. 7 1/4 to 8" (finished top of tread to tread height) are ideal sizes for spaces between the step treads.
hand drive is offline   Reply With Quote
Old 04-30-2012, 06:12 AM   #5
CrossWorks's Avatar
Rewards Points: 150
Couldn't agree more. Best option.
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
The Following User Says Thank You to CrossWorks For This Useful Post:
AtlanticWBConst. (04-30-2012)
Old 04-30-2012, 06:55 AM   #6
Similar Examples:
- Build Well -
Old 04-30-2012, 07:33 AM   #7
CrossWorks's Avatar
Rewards Points: 150
While we're at it, here's another example:
http://www.crossworksme.com/Complete...dan%20Deck.htm
Old 04-30-2012, 12:49 PM   #8
Rewards Points: 3,130
If you're halfway decent at math, making stringers isn't very hard. Google it and see what I mean. All you really need is a rafter square.
Old 04-30-2012, 01:24 PM   #9
Civil Engineer
Rewards Points: 4,790
Some really good ideas from posters. One more idea, maybe not as good as the others. If you simply can't figure out how to make the stringers, and you want to use stringers rather than the alternatives suggested, buy a stringer with an extra step and cut it down to size. Assuming you can get one with the correct rise on the steps, which is usually about 6-1/2 to 7 inches.
Old 04-30-2012, 01:32 PM   #10
That is not a stringer type area (not enough run & height).
If you were going to do anything, it would be a platform stepdown. However, you still need to create a solid concrete pad under such a step-platform. The pad keeps the area from sinking and dropping. In addition, we always pour the pad larger, to serve as a grade level foot-landing.
Example (there is a solid concrete pad underneath the step-up platform. The platform is also secured to the foundation and to the concrete pad):
You could do the wood step with the pad, or, you might want to consider just building a concrete step-landing.
- Build Well -
Old 04-30-2012, 04:43 PM   #11
CrossWorks's Avatar
Rewards Points: 150
Aaaah....the snow. Glad that's gone!
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
