Steps Code? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2007, 08:01 AM   #1
Rewards Points: 152
Steps Code?
Hi All,
I built an addition and will be building a deck off of the back door (next spring). I need to build a little step to get up into my doorway to get my final inspection for my addition.
What is code for these "temporary" steps.
sandyman720 is offline   Reply With Quote
Old 10-08-2007, 08:08 AM   #2
Rewards Points: 5,336
Treads, 11" x 36"and risers between 6" and 8". Call the building dept for your locales parameters.
Ron
Old 10-08-2007, 08:32 AM   #3
Rewards Points: 152
what about a hand rail? does it need to be attached to the house?
Old 10-08-2007, 10:41 AM   #4
I don't think you would need a handrail for one step, but local rules apply, not my advice.
Ron
Old 10-09-2007, 11:00 PM   #5
In Tenn. we all build to the IBC code. step tread is 11"s and with a max step down of 7 3/4"s. Min of 36"s wide stairway.
Handrail isn't needed unless you have four steps.
97catintenn is offline   Reply With Quote
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
underground code tom b Electrical 8 03-23-2008 10:55 AM
Pouring base for preformed steps justdon General DIY Discussions 3 09-01-2007 05:46 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 07:15 AM
