Step Out Of Exterior Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 04:32 PM   #1
Rewards Points: 562
step out of exterior door
was thinking somebody told me once it was not code compliant to open an exterior door and have to make one step down. Have to have a landing of sorts same height as threshold. Old way was a step. Landing or no landing ,,,that is the question??? If I need landing what size should it be??
Dont think replacing one step and slanted to house short walk needs a building permit. Threshold is about 14 inches above dirt level. since no railing required a continuous step around so you can step off any of three ways.
Making small project a concrete solid pour. walk is 20 feet by 3 feet total including new step,possible landing area. Northern Nebraska location if it matters. Tell me what I need to know!
!thanks-don
4just1don is offline   Reply With Quote
Old 07-12-2011, 05:07 PM   #2
AGWhitehouse's Avatar
You can have a step outside the door for residential. 7" height step is recommended. 7-3/4" is max.
Commercial is usually level because of handicapped accessibility and egress requirements.
AGWhitehouse is offline   Reply With Quote
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 12:37 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
Removing a cement step on outside of house Vikeologist Building & Construction 5 06-18-2009 01:33 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-09-2009 12:02 AM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 05:11 PM
