Old 02-14-2009, 09:34 PM   #1
steel or vinyl siding..Whats better?
I have a question we are having trouble with, can anyone help please???House is in the 60's siding is very thick horizontal steel,)NOT SEEMLESS)we are replacing it due to hail damages(thanks to mn weather).We dont know if we should stay with steel(NOT SEEMLESS) or switch to vinyl...... So far we have had no leaking in our basement,Ive read that vinyl can cause leaking into basements? Also my "contractor" was saying something about an " accordion" type of backing that will smoth out the look because its going over wood shingles. I dont know what he's talking about with that either. He didnt mention that vyteck stuff either. My question is, does the steel siding(again not the seemless stuff, just regular) keep the rain out? I know that the vinyl doesnt?
fricandfrac is offline   Reply With Quote
Old 02-14-2009, 11:00 PM   #2
tomstruble's Avatar
both types seamless or not work the same at ''keeping the rain out'' meaning they both leak around any penetrations such as windows and doors.If done properly this leaking is drained out the same way with both products. The accordion foam your contractor is using is to help create a flat plane over your wood shakes
tomstruble is online now   Reply With Quote
Old 02-14-2009, 11:06 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Why wouldn't you have it stripped to the sheathing?
It's a good idea to see if there has been any water damage over the years. Also a good time to add insulation if needed (blown in), replace windows if needed
Last 3 houses I have worked on removing all the siding has revealed ants, termites, bees or some other pest that made a home under the layers of siding
Scuba_Dave is online now   Reply With Quote
Old 02-15-2009, 12:09 AM   #4
Thanks for the speedy reply.. does the accordion stuff need the vytec also??? And we will replace windows if we go the vinyl route, We are doing the roof too. Only $15,000 budget, so I dont think we can afford the stripping of the shingles too...funny the contracter didnt mention this option to us anyway
Old 02-15-2009, 12:11 AM   #5
I meant $18,000. Hit the wrong #
Old 02-15-2009, 02:01 AM   #6
If money is that big of issue,,,strip it off yourself,,thats the easiest part!! Dont need the foam then either,Tyvek over sheathinng,replace winows and let them apply away!!
4just1don is offline   Reply With Quote
Old 02-15-2009, 08:13 AM   #7
tomstruble's Avatar
the foam will help if you strip the house to even out any iregularity in the wall and it makes a nice base for vinyl siding.
i would tyvek over the foam
Old 02-15-2009, 08:20 AM   #8
Remodeling Contractor
I agree with this. At least someone has done some siding work. But must be a small house to do windows, siding and roofing for that budget.
Old 02-15-2009, 08:29 AM   #9
You really need to strip the shakes first. This is the right way to do it. It will allow you to inspect your house for water damage and reinstall proper flashing and housewrap. Spend the money to do it right. I would go with steel rather than vinyl because you will get a lot more return on your investment. I'm sure you'll pay a lot more for steel but the steel is much better.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 02-15-2009, 12:53 PM   #10
Scuba_Dave's Avatar
Ripping the old stuff off is the easiest part
I'm was even able to bundle them & the Town takes them
Not all at once - but I'm only residing one side of the house at a time
Old 02-15-2009, 05:46 PM   #11
tomstruble's Avatar
yes stripping the old siding down to the sheathing is the best way to go.
That being said,i would bet that atleast 80 percent of resides done are over the existing siding
Old 02-16-2009, 08:27 PM   #12
"stripping" sounds good,...but I think we'll have to stay in the "80%".
Old 03-03-2009, 06:52 PM   #13
We are now going to remove the wood shingles!!! Ya!!! We didnt think of the problems that could be under them!!!! Thanks for the insight!!!!
More On This Topic
Reducing Allergies: Mold
Reducing Allergies: Mold by Expert Village
Mold is something that many people that have allergies react to. I find that if you have a very humid house, or you're in a bathroom, or any place that has a lot of humidity, mold tends to grow. It's the dark stuff that grows on your shower walls that... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. In most cities, you'll be required to pull a permit, when finishing your basement. If you maintain open communications, with the city, they'll be able to... Read More »
Air leaks are one of the most significant causes of efficiency loss in home heating. A leaky wall or poorly sealed ventilation results in hundreds of dollars of extra work by your heating or air conditioning unit. Sealing an air leak is not an easy task... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
Hi! I am Steven from Keilholz Flooring on behalf of Expertvillage.com and today we are going to talk about some of the various types of tools you would use to install flooring in your basement. The first and foremost tool would be a standard tape measure... Read More »
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
