Steel Studs Rust Basement Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 06:23 PM   #16
Rewards Points: 83
bergerdude is offline   Reply With Quote
Old 11-04-2011, 12:11 AM   #17
Registered User
Rewards Points: 4,914
"The only concern about steel studs seems to be"------ I have six other concerns about basement steel studs....
1. some s.s. are punched with holes/slots in them, including the top track or plate. These would need to be filled for fire-stopping requirements of the wall/joist bay cavities above;
2. add a sill sealer poly under the bottom plate for an air/thermal break for the air-tight drywall approach and the steel acting as a "heat sink" to the cold slab/earth below;
3. keep the studs from touching the colder concrete wall sucking up your heat or cause "ghosting";
4. air seal the drywall/studs against air with caulking/rubber gasket;
5. fiberglass insulation batt will have inherent convective loops with the steel studs due to design;
6. use rigid foam board at the concrete wall or expect convective loops for certain.
Gary
Old 10-02-2013, 02:24 AM   #18
Rust on steel studs exterior wall (concrete condo)
This thread is from a few years ago but I wanted to resurrect it as we have had a flow of water coming in through our windows apparently from a improperly sealed dryer vent above window. Caulking was redone, wall opened up above window...to find standing water, very corroded steel wall studs and rusty moldy pink insulation.
The leaks have now stopped but the rusted metal studs are visibly streaking the paint on the drywall near the wall with the old leaking windows and adjacent wall that didn't have leaking. Looks like a red flag to me.
What is the remedy for this? Replace studs or paint over? Is it bad to leave corroded studs?
OuiChef is offline   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Steel Studs and Sheetrock slamseven Drywall & Plaster 6 03-15-2011 10:53 PM
Installing Basement Studs jacads Building & Construction 10 03-12-2009 10:25 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Insulation and Steel studs RGardner Building & Construction 4 10-20-2008 09:46 AM
