Steel Studs For Basement, Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 01:05 PM   #1
Rewards Points: 83
Steel studs for basement, size?
Hi,
I have looked at all the information and I have decided to go with steel studs for my basement. (For my reasons, I can't do wood...sorry).
I have done research on this, blocking for hanging stuff, fireblocking, and wood framing for doors, etc. I will be doing this project in little snippets here and there.
I am planning on the 2" XPS on the walls which seems the route that is most advocated. I will use the PT base plate, with plastic between the metal track and PT for chemical reactions from the PT copper.
No vapor barrier, and not sure if I will insulate between the studs or not yet.
My poured concrete walls are wavy, so I will leave a bit of an air gap, so there wont be any support from behind for the perimeter walls.
I have not had been able to source a drywall supply house in the NW suburbs of Chicago, but the big box has Ultrasteel studs at 20g and 25g.
With this in mind.....
What would be the best gauge and thickness of the studs? 20 or 25g...
1 5/8", 2 1/2", 3 5/8" ?
Stud spacing? Standard 16" or less than standard (more $$ but stronger...right?)
Thanks,
I appreciate all the input I can get.
D270 is offline   Reply With Quote
Old 01-18-2013, 01:39 PM   #2
I would go with the standard 16" spacing but use the bigger studs. especially if you are leaving a gap between the foundation wall. By using the bigger studs it will add to the structural integrity of your wall. Something to consider as well id to make braces anchored in your foundation wall and to your studs(about halfway up) should be more cost effective that shortening the span between your studs.
hope this helps
efficiencyhomes is offline   Reply With Quote
Old 01-26-2013, 06:01 PM   #3
Rewards Points: 83
the thicker guage as well
Old 01-26-2013, 06:59 PM   #4
Rewards Points: 3,130
Metal studs in a basement aren't a good idea, no matter what your reasons are. News flash: they rust.
The Following User Says Thank You to md2lgyk For This Useful Post:
joecaption (01-26-2013)
Old 01-26-2013, 07:41 PM   #5
deverson's Avatar
Rewards Points: 77
They are great. If there is enough moisture to rust steel studs then there's going to be mold on wood studs. I use 3 5/8" studs so wiring isn't a problem and I can put 16" fiberglass batts in.
deverson is offline   Reply With Quote
Old 01-26-2013, 09:58 PM   #6
Rewards Points: 636
umm i have not seen a metal stud that has not been galvinized or some other rust preventer on them in years. no need to use treated plate just nail the track to the floor or if really concerned about it lay sill seal down first then track. i prefer 20 gauge over 25 a lot stiffer and a lot less deflection since drywall will be hung on only one side.also may want to add stud stiffeners or spazzer bars since board is on one side only. lay out is 16 on center since common metal studs are only 1 1/4 thick not like standard 2 x wood material at 1 1/2. width i would use at least 2 1/2 but prefer 3 5/8 so at door ways you can frame opening 3 inches wider and 1 1/2 taller and wrap with wood to hang door and trim if using standard wood door frame and wood trim. add wood blocking (or something called danback) at bottom of studs if using wood base trim so it can be nailed on tight. and add blocking to other studs as needed to hang cabinets and other items. insulation at box store will not work since it is made to fit between wood studs and metal studs are hollow so insulation is made wider to fit in hollow of stud and stay in without falling out.
to find products (studs,screws,insulation, and drywall) in your area just google drywall suppliers in chicago or metal stud supplier in chicago and find one near you
here is a manufactures web site
http://www.clarkdietrich.com/product...framing-system
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
TheEplumber (01-26-2013)
Old 01-27-2013, 07:52 AM   #7
DIY staff
Rewards Points: 7,174
Roselle supply----
Old 01-27-2013, 12:26 PM   #8
Registered User
Rewards Points: 526
As your concrete walls are "wavy", use two layers of 1"XPS rather than one layer. Use a square pattern glue bead to lessen the possibility of basement air to the concrete; http://joneakes.com/jons-fixit-database/743
You will get moisture traveling through the cavity as the foamboard is a vapor retarder, not barrier. Wood framing can act as a hygric buffer absorbing water lessening moisture shock, staying wet and warm until dry (unlike steel- rusts even when warm, if wet). The fastener attachment/hole of stud/track looses the galvanic coating at application, and will rust there. You might try spraying each with a rust preventive or similar. The f.g. insulation batts leave full length chases (inherent to design) for air movement and possibly convective loops around the insulation (depending on temperature differences), be sure to close-off all gaps- no matter how small;pp.4, Fig. 4, convection- pp.5; https://docs.google.com/viewer?a=v&q...BiEiG1lHFDd9yA
Be sure the stud wall is not touching the foamboard for conduction and R-value loss or moisture present there; http://www2.dupont.com/Tyvek_Weather...20Bulletin.pdf
The 2" XPS will have a temperature of 40*F (cavity side) for a dew point of 32% RH at 70*F room temp. This using your J, F, and Dec. low temps average; http://www.weather.com/weather/wxcli...graph/USIL0550
Below grade to the "frost line" and above grade.
Use a sill sealer under the plate- wood, metal or composite (60% wood fiber/dough that will mold). It stops air, thermal and acts as a capillary break; http://www.greenbuildingadvisor.com/...-building-code The steel transmit your room heat very well to the colder foamboard and earth under the concrete slab (55*F) much better than wood (even at R-1.25 per inch) ever could. Thermal bridging, pp. 7, insulation charts- pp. 9, 10; http://www.buildingscience.com/docum...ations-r-value The thinner galvanized coated studs could react with the newer pressure treated wood of today, research that.
Gary
Old 01-28-2013, 09:31 AM   #9
Rewards Points: 83
I was planning on putting sill sealer under and over the PT plate, and I agree it's a good idea. Good thoughts about two layers of 1" which may be easier to glue into place, i.e. less stiff.
Thanks. :-)
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
Basement Steel studs gauge/width? bergerdude Building & Construction 2 03-03-2010 03:27 PM
Steel Studs Basement Insulation Woody10 Building & Construction 2 03-03-2010 08:38 AM
Steel Studs Moisture problem bobdd Remodeling 21 06-29-2009 09:06 AM
Steel Studs ? Steve Carpentry 3 11-24-2006 05:10 AM
