Old 03-02-2010, 09:46 PM   #1
Woody10's Avatar
Steel Studs Basement Insulation
I am getting my basement sprayed foamed and am looking at framing the basement with steel studs. I have a friend that installs it for a living and he says he can have me framed quick.
Thoughts on it as opp. to using wood?
Woody10 is offline   Reply With Quote
Old 03-03-2010, 09:30 AM   #2
I personnally like steel studs. I 've used them in basements quite a few times in the past. I stopped using them when the prices became too high. Back then I would shoot a PT 2x4 into the floor and lay the track on the stud. You would need to isolate the wood from the steel now due to the chemical makeup of the new wood. You would also need to upgrade your fasteners. Or eliminate the wood and attach them right to the floor.
I've never had any rusting issues in the basements I've used them in. All the basements have access panels for various reasons so monitoring is simple enough.
I always leave 1 1/2" of space behind the wall for ventilation around the perimiter.
Others will have issues with steel in the basement.
Ron
Old 03-03-2010, 09:38 AM   #3
Drywall contractor
Wood is actually cheaper than metal these days. I use wood for residential purposes, but if a customer specified metal, I wouldn't hesitate to use it. The labor is probably a bit faster. If your friend is donating or greatly discounting his labor, I'd use what he wants to use....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Can I frame over the builders insulation in the basement? ChaoticBliss Building & Construction 35 11-09-2009 01:19 PM
Finishing basement - insulation problem? Gooter Building & Construction 6 08-24-2009 09:23 AM
basement insulation questions CooperChloe Building & Construction 3 02-03-2009 08:54 AM
Insulation and Steel studs RGardner Building & Construction 4 10-20-2008 09:46 AM
insulating between steel studs drewhart Building & Construction 1 09-05-2008 09:07 AM
